Hi everyone,
I am a beginner and i need help with modeling and setting up my SPICE circuit. I’m working on the “Death of Zen” Class-A amplifier (Project 70)
I’m not sure how to correctly define all the sources and connections in the simulation.
Here’s what I have so far:
I need to add an analog signal source at the input (IN), but I’m not sure what the correct syntax or parameters should be.
I also need a +35 V power supply where the schematic shows “+35 V”, but I think it should be referenced to ground — I’m not sure if I connected it properly.
At the output (where the speaker should be), I placed a resistor as the load, but I’m not confident it’s set up correctly or if I chose the right value.
Another issue is that I don’t fully understand how to perform the .tran analysis and parametric sweeps (like varying component values).
I would really appreciate some guidance on how to model and declare everything properly, and how to run those analyses correctly.
Thank you very much for your time and help!!!!
i attached the circuit
