Hello
I have a LVDS clock and LVDS clock distributer
but there is a problem:
when I want to connect the Clock IC to the clock distributer there is a cross path between these components bcoz the P channel of clock distributer is in front of the N channel of Clock IC:
P1--->N2
N1--->P2
now if I want to connect the both P channels to each others I should use a via. (the clock freq is 200MHz)
is there any problem swapping P and N in order to make the layout clean?
P1--->N2
N1--->P2
if so there is no need to use any vias.
Thanks
