Hi all, im fixing up an old (1940's) hydraulic press/bending machine for my dad, He has a small machine shop with some quite old equipment... Ive repaired alot of the bits and pieces down there over the years but this one has me questioning myself and everytime i read and google more on the subject i get more and more confused! lol...
Now i did do a module on dc power supplys at TAFE/Tech about 13 years ago... but i havent had much to do with power supplies since... and the power supplys i dealt with then were with transformers to step down the voltage first and then diodes, caps and coils to rectify and filter the ac into dc..
The Machine im working on has a 2 way hydraulic valve/solenoid... with 220 volt DC coils! I tried to get my dad to go 24volt DC to make things a bit more safe, but they didnt have any stock of the 24VDC coils
so now im stuck with 220VDC for everything
anyhows ill explain the circuit
there is a push button that is momentary, in its normally closed position it causes one of the solenoid coils to energize and pull the solenoid back to the "return position" so all the rams retract...
Then when the push button is pushed.... Mains power goes through a bridge recitifer (i added this when we added new coils, full wave) through the push button switch which has now been depressed, and then into the alternate coil (cutting off the return coil in the process) which then makes the solenoid open and hydraulic fluid push's the rams down....
The moment you take your finger off the button the solenoid goes back to the return position and the rams retract... pretty simple!
We replaced the coils and plugs for the coils... and in the end of the plugs on each coil is a little circuit board with 4 diodes and a small circular red component similar to a ceramic capacitor with only "220" on the side of it.... i assume this is a capacitor? .22uf? so i replaced these boards with the bridge rectifier... now ill probably need some kind of filtering capacitor to replace the one on that little board... what size should i be replacing it with? .22uf? Jaycar have a .22uf 630vdc greencap... will these do? they are the only capacitor i could find with high enough voltage ratings (enough for mains) and 0.22uf I would prefer someone who has some idea about power supplies to give me the go ahead before i hook it up and try it... The coils are worth about $300 each or something i was told... definatly dont want to go frying them
the coils have 35Watts at 220VDC written on the side of them if you need to know that... Ive been reading up on this and got confused with ripple voltages etc etc... I dont own a scope yet and was scared with all the talk of ripple voltages and waveforms that i might have to finally go out and spend the cash on one
Anyhow if someone can point me in the right direction or if ive given enough info for someone who knows to say "yep you need this sized capacitor" that would be nice
The forumla's etc that were starting to mess with my head are here :
http://www.tpub.com/neets/book7/27e.htmhttp://answers.yahoo.com/question/index?qid=20070618213017AASsgCFI know i was on the right path... but yea..
