I've been experimenting with using transmission lines for power conversion. Leaving a note here in case anyone’s interested. It's documented on Hackaday:
https://hackaday.io/project/204242-boosting-voltage-with-a-cable, and I submitted it for their component abuse challenge.
The basic idea is to drive a transmission with with a low impedance square-wave. If the transmission line’s time delay is one quarter the source’s period, the line will boost the voltage. It’s essentially a quarter wave transformer, using a pulse source. The voltage gain for a lossless line with zero source resistance is:
Vo/Vi = R_L / Zo
and with a non-zero source resistance:
Vo/Vi = (R_L * Zo) / (R_L*R_s + Zo^2)
Where, R_L is the load resistance, Zo is the line’s characteristic impedance, and R_s is the source resistance.
Is it practical? Not sure yet. But it is fun to experiment with.
Cheers,
Craig
