Is it possible you need the ferrite beads like in the eval board schematic?
Quote from: CrabxCore on May 21, 2014, 03:46:28 amIs it possible you need the ferrite beads like in the eval board schematic?I had not seen an eval board for it, it should be easy to cut the Vcc track and insert a bead as a test.
Your cold junction compensation is off? What does it read when short circuited with no TC in the socket, and when the TC is at room temerature along with rom temperature from another thermometer.
Quote from: SeanB on May 21, 2014, 03:56:41 amYour cold junction compensation is off? What does it read when short circuited with no TC in the socket, and when the TC is at room temerature along with rom temperature from another thermometer.My take on it is that the MAX chip does the cold junction compensation and applies it to the thermocouple portion of the digital reading. You can read the comp reading separately of course, but as far as I know you don't have to do anything with it.Hmmm... if I disconnect the TC and short the input, the reading is 26°C which would be about right for my office at the moment.EDIT: Adding the bead to the Vcc (before the cap on the MAX) made no difference.
