Hi.
Found this image of the M-Bus Master schematic that I'm interested in. However, I have trouble understanding some parts of the circuit - emphasis on the part labelled "6. quiescent current source". A little bit about M-Bus: master-slave protocol, where the master communicates by varying voltage on the bus, and the slave responds by changing current consumption on the bus. Unit consumption of a slave is 1.5mA, aka the consumption when it is not communicating. There can be many slaves connected to the bus, and their total quiescent current can exceed the "space" event of a single slave during communication, when it increases the current cons. to ~20mA.
So far, I believe the circuit works as follows:
* The 2. part should create the "Space" event with ZD1 zener and emitter-follower circuit (T2); the PNP (T1) can bypass the zener and feed emitter-follower with 37V, making the "Mark" event. T3 discharges the bus when T2 base < bus voltage.
* The 3. part seems a lot like a differential amp. circuit (except the R7 and R12) and would amplify the R9 voltage drop that's proportional to the slave consumption.
* The 4. part, to my understanding, would keep track of the overall slave consumption by charging C3 through R17 and D3. The voltage on C3 would practically not react to quick current changes during slave communication.
* The 5.part compares the voltage from 4. and the amplified voltage from R9 and can differentiate communication current from overall quiescent current.
I also might be completely wrong about the explanation.
About part 6. I believe that T5 should counter the voltage drop across R9, so that the whole bus voltage would not drop when there are many slaves connected. But I have trouble exactly seeing how it plays into the circuit as a whole.
