Thanks for reply - I did some more measurements , looking specifically at duty cycle ( as measured on an oscilloscope vs the calculation ) .
The resistors ( over current protection ) I have 4 * 1 Ohm in parallel = 0.25 ohm and I also tried with three in parallel to get 0.33 ohm .
If the input voltage is raised to 16 Volts , I can get +- 600ma on the 5V output - which is what is needed for the circuit that is powered . BUT ->
I took an IR photo and the device MC34063, and the inductor ( PE 53606 [114uH, 940ma max )] ) outer case is +- 65 Degrees C .
Ideally I could find a more robust device that could accept input range of 12 VDC -> 17VDC and output 5VDC at up to 1.2 Amps - clearly the worst case 12V drop across the device @ 1.2 Amps would require dissipation of 14 .4 watts of heat ,
