Hi, I am hoping you guys will be able to give me some guidance.
# Background
I have a problem where by a some version of a product (printer) are developing are suffering from a problem which is causing the power brick to cut out due to over current. Unfortunately its not all printer are affected and my printer that I have to test with does not suffer with the issue. The product is a printer with a thermal print head (tph), stepper motors and other bits and bobs and I have found out by a combination of a getting a college to plug and unplug various components at various times the tph seems to be causing the issue. The control of the print head is in the hands of a PIC muC and its my job to see what changes have caused this issue. As I said I do not have a product that experiences this issue so I am having to assume (I know) that the problem is a over current.
# The hypothesis
Making the assumption that its a overcurrent but close to the threshold and hence manufacturing variance is causing the issue to not effect all printers but a increase in current usage should be possible to measure and hence I can experiment with different control scenarios etc to help solve the problem.
# The method
Shunt resister and measure the voltage drop on a scope. I have been recommended a 0.1ohm resister to minimise any extra current draw. I have a hantek DSo5102P. I using the probs in what I understand is differential mode either side of the resister with a common circuit ground. I then use the math function to measure the voltage drop.
# The problem
The problem is some draws are short lived and I can't trigger off of the math function (scope limitation) only off channel 1 or channel 2. Any ideas how I could try and get a trigger? The supply voltage is 24v. I have tried ac coupling ch 2 as I read that may help and trigger off that channel but it didn't, I couldn't get a good trigger.
Maybe my entire approach is off. Open to ideas. TIA.
