Easiest/best is to use is a current transformer. This gives you galvanic isolation, common mode rejection, and low power dissipation. If you don't need these advantages a shunt resistors work fine for 15 amp as long as they are rated for the peak of the AC voltage waveform (~170 V).
Hall effect sensors can be used for DC current measurement with galvanic isolation, but they are not needed for 50/60 Hz AC.
