When you say "nice plastic shell", I'm guessing you are referring to injection-molded plastic. For that, you need to be prepared to spend a fair amount of time designing it, or paying a specialist to do the design. Then you can figure roughly about $10,000 or so for the tooling needed to create the molds, which will also take several weeks at least. And finally, you will need to have them made in batches of several thousand items, minimum.
