So I have a collection of 206-0364-01 Tek Microgrippers. They have a maximum voltage of 40 volts written on the side. What exactly sets this? These little clips would be quite useful for looking at the voltage deep inside an older oscilloscope, but I don't want them to arc or melt. Is 40 volts the maximum voltage I should EVER use these to, or is it the maximum voltage it's safe to use while removing and placing the probes with my hands?
Relax, under normal atmospheric pressure, it's actually not possible for an arc to spontaneously form between two points, until the voltage exceeds 327V, which is higher than the peak voltage of 230V mains. An arc can from when the current is interrupted by separating a pair of electrical contacts, or when the mains voltage is higher than it should be.
The reason for the 40V rating is purely for insurance purposes. The insulation isn't mechanically strong enough to ensure it won't be damaged by moderate use and cause an electric shock. Don't hold the clips when they're connected to a hazardous voltage, which is typically above 60VDC or 25VAC.
