Just change the 100K resistor to 75k, and put a trimpot of 47k in series, on this trimpot you can adjust the center of the potentiometer to match the point you want with +-* 25%
Your circuit works, and at center will not have 50% duty cycle, as mentioned from the previous post, in fact, will be 0%, because at center no one of the comparators will work, and depending of the DC offset will decide with comparator will work
