I am trying to modify a switchmode server power supply for adjustable output, from 0 to 42V, by tapping into the feedback loop and adjusting the reference voltage with a 10 turn pot.
I have previously done this with a few ATX supplies using TL494 controller chips, and it usually worked quite well. Except that none of them have survived the torture i put them through (see profile pic). So this time I hope to have a somewhat more robust and powerfull supply that will handle any electronic circuit I throw at it. In the future I also plan on adding a linear tracking output stage to it for better regulation and contstant-current/current-limiting, but I won't worry about that for now.
BTW, the 42V output is rated at 66A, which is about 2.8kW, so I think it should be suitable for most of the stuff I'm going to use it for. Plus 12V, 3.3V and 5V rails adding up to about 300W (from a separate transformer). It also uses a 15A C19 input connector (at 240V).
Now on to modifying it. Firstly I dissabled the over/undervoltage protection. The controller chips is on the primary side, using an opamp and optocoupler (in linear mode) for voltage feedback. The problem though is that the circuit is only adjusting the on-time of the transistors. This is a half-bridge topology, and when I measured the duty cycle I found that I could modify it from 48% down to 33% by decreasing the reference voltage on the opamp, but I soon realised that I was also increasing the frequency from 76kHz to nearly 500kHz! Not so good for the drive transistors. The controller is a CXA8038P
http://www.datasheet4u.com/pdf/CXA8038P-pdf/500903 which has two pins for timing resistors, one for On Time and the other for Dead Time control, with the optocoupler connected to the On Time pin. And two external totem poles for driving the main transistors.
So I'm asking for advice on what the best thing to do here might be. Perhaps someone knows of a simmilar smps controller chip that has fixed frequency but variable duty cycle that I could deadbug into the circuit somehow. As I'd like to keep the overcurrent and other protections. Or an easy method of adjusting both the On and Off time at the same time maybe? Or maybe I should use a low side controller and use two optocouplers to get the drive signals to the mains side totem poles? And also anything I might want too look out for, I have some idea of what I'm doing but i'm no expert.
More pics to come
