Author Topic: Modifying current loop circuit  (Read 1716 times)
Offline sw_guyTopic starter
« on: January 15, 2024, 08:45:45 pm »
Maybe someone could help me to modify the circuit the way that "Smart sensor" part is always on. I think U5 is maintaining stable current only when Rload is connected. And it did not even do that since MAX4493 blew right away I connected power. Not sure why it was chosen to the circuit the first place - for me it looks like it can't handle the worst case voltage scenario. But the primary objective is to keep smart sensor running one way or another.
Offline Doctorandus_P
Re: Modifying current loop circuit
« Reply #1 on: January 15, 2024, 09:28:32 pm »
When I saw those maxim chips I immediately lost any interest.
« Reply #2 on: January 16, 2024, 03:07:14 am »
I am not a fan of Maxim myself either. What I am thinking of is to connect grounds together (switch point) and create a constant current circuit replacing the U5 circuit. However, the accuracy is then as good as the constant current circuit is... and that can be probably mitigated by using the reference voltage that would give a constant reference voltage for the constant current circuit. Maybe there is a better option...
sw guy
« Reply #3 on: January 24, 2024, 09:14:00 pm »
I solved the original requirement separating the smart sensor part (which is STM MCU in practice) totally separated from the circuit. Connection between MCU and DAC is done using SPI isolator. I just have another issue: the DAC I am using (together with the SPI isolator) consumes too much current. I don't think I can use the MAC4493 part for DAC. I could use it to SPI isolator, but still the total consumption is 5.4 mA.
I am iterating options to make it work. Any ideas?
The best idea I've have had so far is to make constant current circuit and make alternative return path.
sw guy
The current version of the circuit is this:
« Reply #4 on: January 25, 2024, 06:31:20 am »
Hmm... maybe just adding a resistor to provide second return path is enough :-)
« Reply #5 on: January 25, 2024, 02:44:16 pm »
I though the idea of adding alternative return path using constant current circuit would work, but it does not. Well, it works, it reduces the current a bit from the main circuit, but still the minimum current flowing thru the measurement load is 5.4mA and it is naturally 1,5mA too much..
