I am developing a method for prototyping electronics that is resistant to transportation. I lack feedback from potential stakeholders in the development of this project. The first two links are for a rough understanding of what is being discussed. Most likely, you will have to use a translator. But the main idea is clear from the pictures.
https://habr.com/ru/articles/808847/https://habr.com/ru/articles/873896/ I would be glad to receive your comments and questions, either with ideas for modules or with tips on where else we can organize discussions.
https://mpp2508.github.io/The site on GitHub pages is for reference once it is organized. It is currently being filled. There is practically nothing there.
I will try to explain briefly why this is necessary. The main idea is to assemble prototypes of electronics in a short time for debugging software or individual hardware solutions. Moreover, this prototype is monolithic, not a tangle of wires on the table. Which is critical if you are developing control electronics for some machine that is located in another place, where you often have to carry the prototype for joint debugging. Or there is a need to carry it from place to place. Even if it is constantly on the table, it is much more pleasant to work with a monolithic prototype than with something that is difficult to move from place to place, fearing to break the design.
In addition, if you have several projects that you periodically return to work on, such prototypes are quickly turned off and put on the shelf, and their place is taken by another similar one.
There is another application for this prototyping approach. If there is a need for equipment that can be assembled by yourself, but it will be in demand once or several times. That is, buying or making it in the usual way is not particularly profitable, because after use it will turn into a dust collector. And if there are modules, you can assemble, use and disassemble.
Something like that.
Keep in mind that the text is written with the help of a translator, so there may be some oddities.
example of a half-scaler project for a 2k display, for exposing photoresist. module with two ssd2828.
| possible option for storing modules
black pill stm32f401
| STLink v2.1
| logic analyzer on cy7c68013a
