The spec I am most worried about is the threshold voltage. I think you may need to know a little more about how it is being used. If it is being driven high enough that there is margin in the current being switched, then it is not a problem. I would hope that it was designed with margin.
Bottom line, maybe a problem, maybe not. Search Digikey for a better solution first--or just roll the dice and try it.
Here are the IV plots from your datasheet, when gate voltage is X-volts, there drain currents are different:
