Author Topic: Mosfet Selection Help, Infineon vs Vishay for Similar Values  (Read 1133 times)
Offline botvinkTopic starter
« on: October 05, 2025, 08:58:12 am »
Hello friends,
For my motor driver design I am in difficulty for selecting the suitable mosfet for 100V range, I am paralelling and eliminated all to 2 model:
IAUMN10S5N016GAUMA1 - Infineon Technologies
https://www.infineon.com/assets/row/public/documents/10/49/infineon-iaumn10s5n016g-datasheet-en.pdf
And
SQJQ112E-T1_GE3 - Vishay
https://www.vishay.com/docs/79384/sqjq112e.pdf
Both are 100V and have similar current ratings, 296A vs. 310A. Vishay is a bit more affordable, but I don't know if it falls behind Infineon in quality or if there are any other significant differences. What do you think?
Online xvr
  • Country: ie
    • LinkedIn
Re: Mosfet Selection Help, Infineon vs Vishay for Similar Values
« Reply #1 on: October 05, 2025, 03:23:48 pm »
Infineon is only 220A Id (not 310A). 310A is a chip limitation, but pins and package itself will limit it much faster.
The following users thanked this post: botvink
Online Siwastaja
« Reply #2 on: October 05, 2025, 04:42:33 pm »
Both current ratings are completely meaningless, so it doesn't really matter.
Calculate maximum actually achievable current from losses (Rds_on and switching losses, latter of which are harder to accurately model) times thermal resistance. Which depends on how heatsinking is done. And maximum ambient temperature.
Online mzzj
« Reply #3 on: October 05, 2025, 06:37:23 pm »
Look to be roughly similar parts. Infineon has bit lower gate charge and thus easier to drive. Body diode ballpark similar.
Vishay has better avalanche ratings but this could be down to different testing methology.
Vishay also has tons of better forward safe operating area but I suspect it could be unrealistic or they even mixed up milli- and microseconds.
Difference between parts is 200-fold. For motor drive this is probably largely irrelevant except  fault/transition conditions.
