If you look at the characteristic curves of the JFET, MOSFET (similar to JFET curves), BJT, and vacuum pentode, they are superficially similar.
Each of these curve sets is a family of curves of I(drain, collector, or plate) vs. V(drain-source, collector-emitter, or plate-cathode).
The JFET, MOSFET, and pentode curves are each for a given V(gate-source or grid-cathode), while the BJT curves are each for a given I(base).
They look similar, because at relatively high voltage they are all roughly horizontal (high impedance).
At the left edge, these devices' curves are a bit different.
Another device, the vacuum triode, has different looking curves since each curve is at a finite slope (medium impedance).
The SOA discussed here is the region inside these I-V graphs where the device can operate safely, as a function of conduction time.
Of course, for switching applications, you try to stay at the bottom (current off, high voltage) or left edge (current on, low voltage) to minimize the power dissipation and keep the device temperature (junction or plate) within safe limits.
Over the rest of the graph, the power dissipated in the device is substantial.
