For improving the key;
Seems like the base might be quite light, add a chunk of metal to the bottom of the case for some more weight, and some little rubber feet.
Maybe a dim LED on the key, if it is easy.
For your speed;
I found that instead listening to each tone/learning each tone, learn the strings. Eg, don't learn a decision tree for the morse, instead just learn the strings.
Practice.
