So I recently just finished this project:
This is my 6 selectable output voltage reference based on an AD780 and IN134.
Schematic attached. I'd been watching some of Scullcom Hobby electronics videos on Youtube and I wanted a reference powered off AA batteries, with a number of selectable outputs of a fixed value. I was on a next to nothing budget - so all the parts I wanted to use were what I'd collected. I wasn't sure about accuracy to be honest,I just picked the most accurate and stable reference I had in my parts box - the AD780BN - and would determine the accuracy after I'd built it.
I also wanted an auto-off feature and one push on button and for it so stay on for 3-5mins. I also wanted it to be portable and fit nicely on my bench. Battery life: about 4 hours non-continiuosly, so decided on 2S2P configuration for my battery supply, that meant using a DCDC converter that could work between 3.0V and 1.6V, though I'd be happy if worked on a minimum voltage of 2.0V. I also wanted a low battery warning LED.Naturally running directly off the output of the DCDC converter supply would not be ideal, so I would have to filter and regulate it with an LDO.
The AD780 had a selectable output by grounding or floating pin-8 on the AD780 - so either 2.5V or 3.0V by using a toggle switch (SW2). The INA134 had pretty good gain linearity. By reconfiguring the connections to the inputs and output feedback, I could get a gain of 0.5, 1.0 and 2.0. I did this using a rotary switch (SW3).
So this meant I could have the following voltage outputs: 1.25V, 1.5V, 2.5V, 3.0V, 5.0V & 6.0V
I built up the DCDC converter based on an LT1073. I needed a supply rail at least 1.6V greater than my maximum required voltage output. with some inductor selection teething and resistor selection I settled on an output voltage of about 8.7V after filter and regulation. A bonus of using the LT1073: it had a free error amp built in, this became the low battery warning circuit. The regulator is an LT1121 LDO and I used a PI filter to get rid of as much switching noise from the DCDC converter.
I then built a number of iterations of my auto-off circuit. The first of which were based on high side switching. these didn't work (rather couldn't get them to work) so decided on a low side switch. The circuits pretty simple: SW1 bypasses the FET Q2. By doing this Voltage on the output of the regulator will have come on, the voltage on the cap will be 0V and the transistor Q1 will be conducting thus turning on FET Q2. The Base current through Q1 charges up C2 until the voltage on the cap is high enough that Q1 stops conducting, turning Q2 off. When Q2 turns off the voltage on C2 discharges through R9, D4, R10. It works well enough for my requirements, however just before it switches off, the current drawn from the supply increases and the low bat light comes on, call this a feature: warning the the unit is about to power off.
One of the iterations:
Once I assembled my reference and amplifier circuit I first measured the output at the reference and confirmed I could switch between the 2 voltages on the fly, which I could. Then I measure the voltages at the output of the amplifier and went through the different switch positions. At lower voltages I couldn't get below 1.35V in the lowest voltage setting (1.25V). This was cos the output of the amp was hitting its minimum rail which is about 1.3 to 1.4V above 0V. This meant sticking in an inverter circuit. An ICL7660 IC was kicking about so hooked that up and connected it up to the amplifier negative supply rail. A retest and I was able to get 1.25V.
So before committing my design to veroboard, I gave it a quick teat to see how the accuracy was. I had access to a HP 34401A and measured the output voltages:
Test setup:
I then stuck it all on veroboard and in a convenient case that already had a battery compartment and aluminium panel, which I drilled some holes for LED's, switches and connectors. Yes connector spacing is 19.05mm or 3/4".
After sticking it all in a box I gave it another test, this time using a Keysight 34972A DAQ at work, fresh a month out of the box! Here are the results:
Test setup:
Seems that 2.5V based outputs are less accurate than 3.0V. Not sure why this is, but either way I'm happy with the performance. I printed out my results and stuck them to the box for reference:
I plan to test my unit against temperature also using the DAQ at a later date.
I'm pretty happy it turned out anyway, thought I'd show and tell it, and see if anyone can offer any insight into anything I could have done better, or I did wrong - feel free to pick at it.
