Author Topic: Mysterious pcb tracks? Antenna? What is it?  (Read 1684 times)
Offline perandersTopic starter
    • Sjöström Audio
« on: August 17, 2026, 08:21:53 am »
The pictures show a light relay and is powered using a capacitive voltage divider (common in time relays). This serpentine pattern, what is it for? I have no clue. (Pay no attention to the yellow arrow in the picture.)
« Last Edit: August 17, 2026, 08:23:27 am by peranders »
/Per-Anders or P-A as my friends call me.
Offline iMo
  • Country: li
Re: Mysterious pcb tracks? Antenna? What is it?
« Reply #1 on: August 17, 2026, 08:55:03 am »
..  it looks like an XXXnH inductor wired in series with the resistor and something else (ie a capacitor) at the relay contacts. Perhaps a snubber or something like that..
The following users thanked this post: Uunoctium
    • Sjöström Audio
« Reply #2 on: August 17, 2026, 01:27:25 pm »
Inductor? Isn't the meander pattern cancelling the inductance?
Offline Andree Henkel
« Reply #3 on: August 17, 2026, 01:57:07 pm »
could also be a resistor made of copper track
or a delay line
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #4 on: August 17, 2026, 02:05:35 pm »
In this context, a fuse
Day Job: Mostly LEDs
Online Doctorandus_P
« Reply #5 on: August 17, 2026, 02:16:06 pm »
I don't believe it's a fuse in this case, because it is in series with a resistor.
With a PCB track used as a fuse, there is usually also a section that is noticeably thinner then the rest of the track, to make it predictable where the fuse blows.
(The video that Mike made about such a fuse destroying a whole microwave is excellent though)
Online MariuszD
« Reply #6 on: August 17, 2026, 02:27:02 pm »
The meander is connected in series with a resistor and a capacitor supplying power to the electronic circuit.
I estimated the resistance at 150mΩ and the reactance at less than 1mΩ. I don't know the resistor, but such resistors usually range from 100 Ohms to 1k Ohms.
The resistance and reactance of the meander are negligibly small compared to the nearby resistor.
Offline Alex Eisenhut
  • Place text here.
« Reply #7 on: August 17, 2026, 11:50:49 pm »
There appears to be a pattern of marks on the ... pattern. I mean it looks like the solder has been deformed by being held in a vise or something. Could this just be a contact for inserting into something??
Offline gbaddeley
« Reply #8 on: August 18, 2026, 03:39:47 am »
The long trace Isolates the temperature rise of the resistor from the relay contacts and the connector ??? Just guessing. Looks like the resistor gets pretty hot, as the phenolic pcb is darkened.
Glenn
Offline Kalvin
  • Embedded SW/HW.
« Reply #9 on: August 18, 2026, 07:22:22 am »
My guess: extra copper was added in order to balance the amount of copper on the pcb so that etching would not etch out that single trace.
Offline Seekonk
« Reply #10 on: August 18, 2026, 09:28:28 am »
This is part of a capacitive dropping power supply.  I believe it is a vain attempt to add some lightning protection. While the inductance would seem to cancel out, things like this drive lightning spikes crazy.
    • Sjöström Audio
« Reply #11 on: September 01, 2026, 06:40:05 am »
Could this have something to do with wave soldering? Some sort of solder trap?
