Author Topic: NE5532 Op-Amp IC circuit Diagram  (Read 25881 times)
Offline devin23bTopic starter
« on: February 14, 2017, 06:59:26 pm »
Hi, I wanted to make a "quality" electrit mic amp.  I have built a simple pre-amp, but wanted to boost that a little also.  Any advice?
Offline Zero999
  • 0999
Re: NE5532 Op-Amp IC circuit Diagram
« Reply #1 on: February 14, 2017, 08:02:40 pm »
Increasing the gain will boost the output, up until a point. Beyond that the output will clip and become distorted.
Please post a schematic.
« Reply #2 on: February 14, 2017, 08:55:57 pm »
Image result for ne5532 schematic
Offline Buriedcode
« Reply #3 on: February 14, 2017, 09:42:04 pm »
Electret mics contain a built-in JFET that requires mic bias to be applied via a resistor, usually 2-10V via a 2k2 - 10K resistor. Very rough numbers.
What you have posted is power amplifier with a gain of 10 (R5 and R6 form a voltage divider for negative feedback).  Q1 and Q2 provide a higher current push-pull output than the 5532 can on its own, so it can drive small speakers.
What is the application? Is this mic being used with a 'line-in' on equipment? or are you actually driving a speaker?  Either way I would recommend googling a 'low noise preamp' to get your mic signal up to line level, then a power/speaker amplifier if you wish to drive speakers with it.
I have seen a few transistor preamps with very low noise, and there are single transistor preamps that will give you plenty of gain but perhaps not overly quiet. Opamp preamps can be very low noise but with any preamp, the bias for the electret mic provides a path from the power supply, to the amplifier input and so any noise on that line gets amplified.  I have no idea if you are a hobbyist, or what 'skill' level you are at (not that its something that can be measured!) but assuming you're just starting out, I would suggest looking for single transistor amplifiers, googling how they work, and playing about with component values.  If you just want a 'quality electret preamp' google has many examples!
The NE5532 is a very capable opamp for audio but if its for a preamp (driving line level input) you won't need the transistors on the output.
« Reply #4 on: February 16, 2017, 06:15:44 pm »
Image result for ne5532 low noise electret preamp
This one seems a little more simple and is just a preamp, does this seem like it would works better?
Offline Zero999
  • 0999
« Reply #5 on: February 16, 2017, 06:41:47 pm »
Yes, that's better.
The following users thanked this post: radzeck
Offline danadak
« Reply #6 on: February 18, 2017, 12:25:29 pm »
Here is a single supply circuit / reference design -
http://www.ti.com/lit/ug/tidu765/tidu765.pdf
Regards, Dana.
Offline Zero999
  • 0999
« Reply #7 on: February 18, 2017, 02:08:46 pm »
Regards, Dana.
That's an interesting design. It will work well from a clean power supply such as a battery. If it is to be powered from more noisy power supply, then another RC filter can be added before the microphone biasing resistor (R1) to help to improve the supply rejection.
Offline Audioguru
« Reply #8 on: February 18, 2017, 04:36:02 pm »
Why did you show a 32 ohm speaker? 32 ohms is an earphone, not a speaker. With an earphone in your ear you do not need gain much more than 10 times. You also do not need a 24V supply.
Your new NE5532A preamp can drive a power amplifier, not a 32 ohm earphone and not a speaker. The 4.7uF output capacitor cuts frequencies below 57Hz when the load is the minimum 600 ohms that the opamp can drive.
Offline StillTrying
  • Country: Broken Britain
« Reply #9 on: February 18, 2017, 04:43:57 pm »
Hero999:That's an interesting design.
Agree, but I've not got very far in simulating it.
« Last Edit: February 18, 2017, 04:49:04 pm by StillTrying »
