Thanks very much Alan! This particular situation had me stumped. I was thinking of deliberately applying a tad of offset at the immediate base input (for offsetting the message), but didn't go ahead with it - due to the data sheet. But I'll definitely try that out now that you kindly indicated it can be done. I'll just add a tad, following your recommendation.
Btw..... it's a big world, but yet a small one! I'm the same one that very recently asked you about the long tailed pair - regarding the Q2 turning off for relatively small rise of voltage at the base of Q1. I didn't know you were on this forum too. Very nice to catch you here too! And thanks for helping me.
For the NE612, I was only able to get the AM signal after following some very old forum discussion (which I wasn't involved in) about putting a potentiometer (eg 500K pot) between pin 1 and 2, with the wiper part of the pot connected to ground. This was mainly to fix up the asymmetry between first half and second half cycles of the AM signal (like due to uneven gains on each half). The pot certainly helped, but I think the number of turns on my pot wasn't high enough (ie. I used less than 500K pot).... so it was very sensitive around the spot where I needed to turn it. After that, I noticed some small AC signal getting through to the output when I had the message signal connected (for the case with no LO signal applied). So I used that same potentiometer to null it out as much as possible. And then, after that, I applied LO and message signals (with no external DC offset applied), and out came nice clean symmetric AM signal. The screenshot I loaded was for the case where I reduced the modulation depth, as it was at around 100 percent when I first noticed that I was getting AM at the output. I'm thinking that changed internal bias due to the external pot has allowed the AM to come through. But I was really preferring to add my own DC offset. Thanks again for helping and showing what to do Alan. I certainly will be looking at the Gilbert cell video! I hadn't come to that one yet, but I noticed it, and it was going to be the next part of watching, after understanding what you taught about the long-tailed pair. Thanks Alan!
