@bdunham7
The raw 70v is direct from rectifier/filter and the capacitance can be varied.
The audio amp input caps are more difficult to change due to space on the PCB
The regulators will only feed the audio power amp.
enut11
Just one question: why are you using a regulated power supply, for an audio amplifier? It's not normally necessary, since the power supply rejection of a well designed amplifier makes voltage regulation unnecessary.
If the design you're using is for 60V, but you have 70V, on the filter capacitors, then it's better to modify the circuit for the higher voltage, than to add an unnecessary voltage regulator. It's probably as simple as increasing the voltage ratings of a few components and using larger heat-sinks.
EDIT:
I've just read the original post again and I'm confused.
I want to regulate a raw +/-70vDC supply to +/-60vDC at less than 100mA. It is a low noise metrology project so aiming to use analog chips.
I found the TL783 125v will do the positive side but have yet to find a suitable negative chip.
Any suggestions from the analog gurus?
enut11
Now you say it's an audio amplifier.
Please post a schematic or data sheet for what you're powering.
