What I have is the beginning of a robot controlled by an xbox360 controller with a usb shield....
I have 2 servos controlled with one joystick, (up, down, left, right)... I have "Serial.print" displaying the movement in a terminal...
I have the sabertooth motor driver being controlled by serial pin 1 TX with the other joystick output.......
The pan and tilt servos work fine but the two motors are getting less than desired results....
Does the serial printing from the servos interfere with the motor signals coming out of TX1?
I can post the code if you need to look at it but it is UGLY.....
