Warning: long post ![Cool 8)](https://www.eevblog.com/forum/Smileys/default/xcool.gif.pagespeed.ic.cOxV6sPNRd.png)
BTW..I assume by the flag on your post you are from the Netherlands/Holland/ Pays-Bas/ the low country...not 100% sure. I never know just what to call "Holland"...lol
Holland is what most people call it, after two main provinces
The Netherlands is the official name
Les Pays-Bas is how the French decided to call our country
Personally I prefer The Netherlands
I already said I play electric guitar myself, so I couldn't help but keep thinking about how I'd approach this. (Still won't be able to take on the project for several reasons, sorry)
One question you need to know the answer to is the reason that the guitarist in question doesn't want to use both amplifier as they come. Does that have to do with too much hassle moving two sets of amplifiers, or whichever. This is to figure out the core question behind the suggested solution of creating both into a single amplifier.
Still, some possible solutions in no particular order:
1)
A modelling amplifier with flat response monitors and line out to PA.
The way to go in that case is the Axe FX II from Fractal Audio. It receives high praises and several recording artists have switched to using this processor unit for their live tours. It is supposed to sound so close to the original amplifiers it cannot be distinguished albeit in a recording studio maybe. It’s dynamic response to the way you play is also said to be very close to a real tube amplifier. Over at The Gear Page for example there are many posts about it. (One warning about that forum: there are quite a few examples of snobs and audiophools over there, so read between the lines to figure out who knows his/her stuff and who just has too much money, but YMMV)
I also can understand that there are many players out there that want the 'real deal' tube amplifier behind them on stage and simply don't want a modelling processor, however good it might be.
2)
One amplifier head each of the Bassman and the EVH 5150. Maybe put them together in a single flightcase. Use something like a Radial Switchbone amplifier selector to switch between the two. Depending on the guitarists requirements you can use one speaker cabinet, or more than one if different speaker types (V30’s, greenbacks etc) are required.
You can always go out of your way and create a complete ‘rig’ where everything sits in one big flightcase on wheels, effects all through a midi controlled looper, amplifier channel switching too; and the guitarist only has a midi controller switchboard in front of his feet.
One close example I could find would look like this:
![](http://i42.photobucket.com/albums/e315/whitechapelgore/rackfront.jpg)
(You'd still need to turn a Bassman combo into a head + speaker cabinet)
3)
Basically the same, but now you try to get the circuits of both amplifiers into a 19” rack sized chassis for easier building.
4)
Design the desired amplifier into a single chassis.
A few things to figure out before getting started:
Power supplytube amp power supplies aren’t the most well engineered actually. But somehow those inefficient, not really completely DC power supplies play a role in what guitarists like about a certain amplifier. (The VOX AC30 comes with a tube diode, which for modern electronics engineers is plain weird, but for guitarist seems to be great for the overall sound produced.)
In other words: figure out the similarities and differences between the two power supplies. From an engineering point of view, you’d want to combine everything into one power supply circuit and one single transformer, if possible. It might result in that you need a custom made transformer in that case.
Preamplifier circuitsI’d suggest you keep those as close to the original as possible, including physical layout. Inevitably you need a few signal relays to switch signal paths between either preamp circuit. I’d suggest to find pictures of the inside of main brand channel switchers like Mesa Boogie’s or Bogner’s top of the line models to see which relays they use.
Power amplifiers:Now you might already know, but the power amplifier including the output transformer does quite a bit on shaping the ‘color’ of the sound. Worst case you’ll need to recreate both amps completely from power supply to preamp and power amp including using the same transformers as the original or aftermarket replacements. So one thing to test is what it sounds like if you use the Bassman’s preamplifier’s output into the EVH’s power amplifier stage. If that sounds OK, you only need to replicate the EVH’s power amplifier stage. (If not, than you might really be better of trying to get two separate amplifiers in a single space and only switch where the guitar/speaker signal goes to/comes from.)
Effects loopPlaced between pre- and power amplifier; you probably need a buffer stage before the effects loop output and a likely a buffer at the return. Being part of the signal path their circuits and layout will somewhat shape the sound. You need to decide whether you want the effects loop to be a parallel circuit or a serial circuit, or either but switchable. Maybe copy this from the EVH circuit?
IMHO it is best to keep the effects separate from the amplifier. You can always put the effects processor into the same physical case of course.
Speaker choiceThis is completely up to the guitarist’s taste. With a bit of luck only one type of speaker suits his/her needs for both clean and overdriven sounds. In any case I'd suggest separate cabinet. (I do know of some guys who use two sets of speakers in a single 4x12 cabinet. Not sure if he uses all together or in two pairs with two separate inputs to the cabinet)
I hope this helps you / your-designer-to-be to get started somewhere.
Since you have experience building replicas you might get a lot further by yourself than you think: say you are able to create a system design where the main parts of the circuits are just 'existing modules' that need the right interconnections. In that case you might be able to create the replica circuits yourself and only need a third party for the right interconnects and channel switching design. Just thinking out loud here.
Anyway, this is where I sign off. Best of luck!
- Christean
