Here is a many things in repairing notebooks...
Do you check PL10 and PL11 to the ground for short-cirquit? May be it is a trouble?
Also, double re-check, if the firmware in SPI flash is correct. (if you have an SPI programmer, i recommend you to re-flash a firmware (Backup of existing dump is strongly recommended!!!)
