Author Topic: Need help identifying a transistor  (Read 3441 times)
Offline WuerstchenhundTopic starter
  • Able to drop by occasionally only
« on: January 26, 2013, 05:31:35 pm »
Hi!
In the fight to fix my Artesyn XL130 power supply I need some help identifying some kind of transistor. It has the following writing:
A431
756-D
94321
I guess the last row is just a production date but so far I couldn't find much with the other numbers.
Does anyone know what type of transistor this is? And maybe some alternative part I which is easier to source and which I could use instead?
Offline fmaimon
  • Country: br
Re: Need help identifying a transistor
« Reply #1 on: January 26, 2013, 05:42:33 pm »
It's a TL431 or similar shunt voltage reference.
Offline mark-r
« Reply #2 on: January 26, 2013, 10:20:03 pm »
Unlikely to be a 2SA431 I'd have thought. That's a germanium RF transistor unlikely to turn up in a power supply. It's also been obsolete since the 70s and was in a 4 lead TO72 metal case.
Offline bitwelder
« Reply #3 on: January 26, 2013, 11:15:18 pm »
The logo on top of the A431 is that one from Astec. A quick search for Astec A431 brings e.g. to this datasheet:
http://images.ihscontent.net/vipimages/VipMasterIC/IC/ASTC/ASTCD005/ASTCD005-1.pdf
(three-terminal precision adjustable shunt reference)
« Reply #4 on: January 27, 2013, 12:30:24 am »
TL431 looks good, and they are easy to get.
Many thanks for the help!
