EEVblog® Electronics Community Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Need help to identify diode
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Need help to identify diode (Read 1390 times)
ksb
Contributor
Country:
on:
September 16, 2018, 02:29:08 pm »
Friends,
Can someone suggest me the replacement part for diode below. The marking code is T1 J8H.
Logged
Benta
Super Contributor
Country:
Re: Need help to identify diode
Reply #1 on:
September 16, 2018, 03:27:04 pm »
Looks like a Vishay hermetic glass rectifier. High reliability and high tolerance of thermal cycling and high temperatures.
Originally Telefunken, I believe.
EDIT: correction, it's called a "sintered glass" rectifier.
Last Edit: September 16, 2018, 08:44:13 pm by Benta
Logged
drussell
Super Contributor
Country:
Hardcore Geek
Reply #2 on:
September 16, 2018, 05:17:45 pm »
That looks like an SOD-57 size package, SOD-64 is a bit "fatter" and "rounder." Not that the package type helps much since you used to even be able to get 1N400x series diodes in that package, it could be anything...
Argh... Are either one of those still good so you could do some tests?
It does seem to be an awful lot like a Telefunken part number, though:
https://www.tedss.com/2028003173
https://www.vishay.com/docs/86028/byt51a.pdf
etc...
Edit:
Also, what are these diodes out of? What is the application?
Last Edit: September 16, 2018, 08:59:25 pm by drussell
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog® Main Site
EEVblog® on Youtube
EEVblog® on Twitter
EEVblog® on Facebook
EEVblog® on Odysee
