Author Topic: Need Schematic For DIY Controller  (Read 456 times)
Offline administr4torTopic starter
« on: June 01, 2026, 05:13:58 pm »
hi,
https://www.eevblog.com/forum/chat/help-finding-replacement-for-this-bldc-fan-controller/msg6253715/#msg6253715
Can someone help with BLDC controller?
I need to either mod the one I found below or create a new one from scratch, please help
yeah, thats one of the reason I am trying to find alternate, why pay $350 when you get it cheaper elsewhere?
I found this, do you think it will work? the Audi one is rated for 60A, while Triumph one is rated 20A (?) atleast thats the fuse I see in Triumph diagram.
https://www.amazon.com/-/fr/No-8E0959501AG-8E0959501AB-8E0959501K-ventilateur-refroidissement/dp/B0CHS8X9QW
below is PIN out and OEM Audi Electrical diagram for the Audi cooling fan PWM module
if you think it will work, what pins replace what pins , i need conversion of pins between amazon and triumph module, based on information above.
Thanks for helping me out
[/img]
its for a Radiator Fan for automobile car
OEM part is out of stock
any way I can find a replacement part for it somewhere?
please help
THanks
Offline coromonadalix
Re: Need Schematic For DIY Controller
« Reply #1 on: June 01, 2026, 07:38:04 pm »
but you had some good answers on the other duplicate thread,  you should have stayed on the other, normally multiples post are not tolerated
the given schematic idea could be a base to build your own ...
if not, scrap yard  LKQ,  kenny u-pull   pintendre auto  etc ...
« Last Edit: June 01, 2026, 07:58:16 pm by coromonadalix »
Offline moffy
« Reply #2 on: June 01, 2026, 09:51:15 pm »
The schematic by Randy222 is almost all you need, if you have some electronics exposure, not everyone does, otherwise just a 12V PWM controller of suitable current, with a little logic would do.
