Hello
I need to generate ~ -28V at 5mA for a LCD bias voltage, from a 5V supply with some components that i have at hand ( i can't place any order right now + it's a one-off )
I've thought of a simple royer circuit using some ring cores i had available:
http://www.kaschke.de/fileadmin/user_upload/documents/datenblaetter/Ringe/R30-5.3.pdfhttp://www.kaschke.de/fileadmin/user_upload/documents/datenblaetter/Materialien/MnZn-Ferrit/K2006.pdfthe inductor values are not optimized - i can reduce L1 and L2 to 5 turns without saturating the core.
Also L6 - i'll pick up something that i have available ( 470uH for example )
Q1 and Q2 form the royer oscillator. C1 sets the oscillator frequency - i'll tune it so it oscillates at ~ 100kHz
Q3 is used as an enable signal - there must be a delay between 5V and -28V otherwise the LCD drivers go crazy.
If i'm careful i can fit almost all components inside the core ( hot-glue everything in place once it's finished and forget about it )
C3 acts as a inrush current limit so the circuit will not overload the 5V rail on start-up and will limit the current if the LCD drivers decide to go crazy.
I don't think a charge pump / voltage multiplier will work with this voltage ratio ( almost 6:1 )
Are there any other solutions ? Maybe a 1 transistor oscillator ?
Or a 1 transistor fly-back - will it work with a simple ring core ? i have some E32 and E42 cores available but they are too big.
In the image:
green - output voltage
red - enable signal
yellow - input current
I've attached the LTspice circuit / simulation.
