Author Topic: New DIY Metcal compatible soldering station  (Read 4610 times)
Offline fireworksTopic starter
  • Country: hk
« on: June 14, 2018, 02:02:03 pm »
  There is a new open source project for a DIY Metcal compatible RF generator:
    https://github.com/SergeyMax/SolderingStation
  It also has a Youtube video:
  The output power is 80W, so it's higher than the 40W or so of a MX500.
  Looks very promising!
The following users thanked this post: edavid, 001
Offline apblog
Re: New DIY Metcal compatible soldering station
« Reply #1 on: June 15, 2018, 12:26:06 am »
Dumb question... 80 Watts is a lot of RF power, or so I recall from my days of setting up antennas on rooftops.  We were warned to be careful of 100 Watt microwave dishes, for example.
Is this thing gonna roast my eyeballs?   :D  :-//
Like this guy —>  :o
OK, obviously not, but WHY not?  The idea of an RF soldering iron has always scared me a bit.
Offline David Hess
  • DavidH
« Reply #2 on: June 15, 2018, 12:36:11 am »
Even 5 watts of RF can give a serious RF burn but in this case all of the RF is absorbed in the soldering tip instead of being radiated so it is not a problem.  It is no more dangerous than applying 80 watts of RF to a dummy load.
Offline Towger
  • Country: ie
« Reply #3 on: June 15, 2018, 04:08:29 am »
80w is what the newer 5200 base stations output and handles support.
Offline CristopherD
« Reply #4 on: June 16, 2018, 04:42:33 am »
how does this compare to the older metcal irons?
i think they had 433mhz and 13.56mhz?
There was a DIY metcal thread here
https://www.eevblog.com/forum/projects/diy-metcal-13-56-mhz-rf-supply/500/
Online helius
« Reply #5 on: June 16, 2018, 06:48:25 am »
The Metcal products with F connectors (including all the original ones from prior to the OK Intl acquisition) are 13.56 MHz (ISM band).
Some of the newer products have three-pin circular connectors and operate at 450 kHz (SRD band for avalanche beacons). This system was mainly developed, as I understand it, to better compete with the prices of ceramic-cartridge products like Hakko or Weller.
« Last Edit: October 04, 2020, 08:01:06 pm by helius »
Offline rfmerrill
« Reply #6 on: October 04, 2020, 07:42:10 pm »
Sorry for necro, but did anyone actually try building this? I just made a big post on my build in this same subforum here: https://www.eevblog.com/forum/projects/i-built-the-diy-metcal-compatible-soldering-station/
