Author Topic: newbee NGSpice KiCAD question  (Read 1920 times)
Offline Pannenkoek_met_een_lampjeTopic starter
« on: December 09, 2018, 10:09:16 pm »
Hello just trying to learn NGSpice, I use KiCAD to make the schematic. I did a few things of the following to check if it works:
http://ngspice.sourceforge.net/ngspice-eeschema.html
the filter and transistor schematic works so thats great. So I though lets try a comparator with 3 opamps. When I try to RUN this in NGspice I get:
Circuit: KiCad schematic
Too many parameters for subcircuit type "lm324" (instance: xxu1)
Background thread stopped with timeout = 0
Reducing trtol to 1 for xspice 'A' devices
Doing analysis at TEMP = 27,000000 and TNOM = 27,000000
No. of Data Rows : 11
my lm324.mod file looks like this:
* Legal Notice: This material is intended for free software support.
* The file may be copied, and distributed; however, reselling the
*  material is illegal
* For ordering or technical information on these models, contact:
* National Semiconductor's Customer Response Center
*                 7:00 A.M.--7:00 P.M.  U.S. Central Time
*                                (800) 272-9959
* For Applications support, contact the Internet address:
*  [email protected]
*LM324 Low Power Quad OPERATIONAL AMPLIFIER MACRO-MODEL
* connections:      non-inverting input
*                   |   inverting input
*                   |   |   positive power supply
*                   |   |   |   negative power supply
*                   |   |   |   |   output
.SUBCKT LM324       1   2  99  50  28
*!!!!!!/NS weggehaald bij SUBCKT
*Features:
*Eliminates need for dual supplies
*Large DC voltage gain =             100dB
*High bandwidth =                     1MHz
*Low input offset voltage =            2mV
*Wide supply range =        +-1.5V to +-16V
*NOTE: Model is for single device only and simulated
*      supply current is 1/4 of total device current.
*      Output crossover distortion with dual supplies
*      is not modeled.
****************INPUT STAGE**************
IOS 2 1 5N
*^Input offset current
R1 1 3 500K
R2 3 2 500K
I1 99 4 100U
R3 5 50 517
R4 6 50 517
Q1 5 2 4 QX
Q2 6 7 4 QX
*Fp2=1.2 MHz
C4 5 6 128.27P
***********COMMON MODE EFFECT***********
I2 99 50 75U
*^Quiescent supply current
EOS 7 1 POLY(1) 16 49 2E-3 1
*Input offset voltage.^
R8 99 49 60K
R9 49 50 60K
*********OUTPUT VOLTAGE LIMITING********
V2 99 8 1.63
D1 9 8 DX
D2 10 9 DX
V3 10 50 .635
**************SECOND STAGE**************
EH 99 98 99 49 1
G1 98 9 POLY(1) 5 6 0 9.8772E-4 0 .3459
*Fp1=7.86 Hz
R5 98 9 101.2433MEG
C3 98 9 200P
***************POLE STAGE***************
*Fp=2 MHz
G3 98 15 9 49 1E-6
R12 98 15 1MEG
C5 98 15 7.9577E-14
*********COMMON-MODE ZERO STAGE*********
*Fpcm=10 KHz
G4 98 16 3 49 5.6234E-8
L2 98 17 15.9M
R13 17 16 1K
**************OUTPUT STAGE**************
F6 50 99 POLY(1) V6 300U 1
E1 99 23 99 15 1
R16 24 23 17.5
D5 26 24 DX
V6 26 22 .63V
R17 23 25 17.5
D6 25 27 DX
V7 22 27 .63V
V5 22 21 0.27V
D4 21 15 DX
V4 20 22 0.27V
D3 15 20 DX
L3 22 28 500P
RL3 22 28 100K
***************MODELS USED**************
.MODEL DX D(IS=1E-15)
.MODEL QX PNP(BF=1.111E3)
.ENDS
Can anyone tell me what might be wrong? This might be very simple thing but I am  new with NGSPice so some help would be great
thank
Offline SiliconWizard
Re: newbee NGSpice KiCAD question
« Reply #1 on: December 11, 2018, 01:27:15 am »
Can you post your KiCad schematic file? Or just the Spice circuit file for that matter.
Most likely the opamp symbol you're using has more pins than the 5 ports declared in the LM324 subcircuit and the extra pins end up in the spice netlist.
