Author Topic: not work  (Read 24382 times)
0 Members and 14 Guests are viewing this topic.
Offline AigarsTopic starter
  • Country: is
  • elerepair
not work
« on: May 26, 2014, 07:49:55 pm »
hi guys, maby u undertend, whats can be wrong.
Online tom66
Re: not work
« Reply #1 on: May 26, 2014, 07:52:24 pm »
You have several solder bridges on the board, I am not sure if they are intentional.
Offline Thor-Arne
  • Country: no
  • tinker - tinker, little noob.....
Re: not work
« Reply #2 on: May 26, 2014, 08:23:02 pm »
Perhaps a contrast trimmer for the LCD ?
Offline 128er
Re: not work
« Reply #3 on: May 26, 2014, 08:34:38 pm »
At first glance i would guess the same. Make the contrast voltage adjustable. Seems like you have fixed the contrast voltage with a divider? What voltage is on (i guess) pin 3?
Schematic would also be good and code from the atmel controller.
« Last Edit: May 26, 2014, 08:39:54 pm by 128er »
Offline Balaur
Re: not work
« Reply #4 on: May 26, 2014, 08:41:27 pm »
It looks to be a version of the AVR Component Tester. Maybe this one.
Offline Neganur
Re: not work
« Reply #5 on: May 26, 2014, 09:13:28 pm »
bit hard to tell but I think most of what looks like solder bridges is actually glare from the left-over flux. I'd look into a contrast trimmer too, caught myself forgetting it a couple of times :P
Offline Mr Simpleton
  • Not the sharpest knife in the drawer
Re: not work
« Reply #6 on: May 26, 2014, 09:21:04 pm »
What about ground... I fail to see how the groundplane in lower left is connected to the other ground??  :-//
Offline Balaur
Re: not work
« Reply #7 on: May 26, 2014, 09:31:03 pm »
It looks to be connected on the left switch side (and through the switch itself)
Offline TerraHertz
    • It's not really a Blog
Re: not work
« Reply #8 on: May 27, 2014, 01:10:45 am »
This. No, they're not bridged by the pushbutton.
Also, the two small diodes - what happened to them? Using thin leads as scope probe clip points is not a good idea.
Anyway they both have mangled leads, perhaps they are fractured?
Edit: Oh wait. Are those actually surface mount resistors with wires soldered to them?
« Last Edit: May 27, 2014, 01:13:35 am by TerraHertz »
Offline TVman
  • Life is A bunch of people staring at computers. ;)
Re: not work
« Reply #9 on: May 27, 2014, 01:17:07 am »
Yes,
Yes they are... :)
Yeah, I play Minecraft!
But I'm on here more because I learn more. :D
Offline ajb
Re: not work
« Reply #10 on: May 27, 2014, 02:50:47 am »
I'm not seeing any breaks in the ground plane.  The area on the lower left that appears at first glance to be isolated looks to be connected by a single thermal track on one of the TO-92 pads.
There are a number of HD44780 libraries for the AVR that don't have proper initialization sequences, and may or may not properly reset any given LCD controller.
  • Country: is
  • elerepair
Re: not work
« Reply #11 on: May 28, 2014, 10:38:26 am »
there its sam mor
Offline Neganur
Re: not work
« Reply #12 on: May 28, 2014, 11:10:17 am »
You need to look into using a contrast potentiometer.
That static voltage divider is doing you no good unless you know exactly what value you need for your specific display.
Þú þarft að líta inn með andstæða potentiometer.
Truflanir spennu Divider er að gera þér ekki gott nema þú vitir nákvæmlega hvaða gildi þú þarft fyrir display.
Tac Eht Xilef
  • Guest
Re: not work
« Reply #13 on: May 28, 2014, 11:14:56 am »
4th'ing this. I've got a bunch of very similar looking displays from DX that are very picky about the contrast voltage, and the up/down viewing angle is terrible at best. Unless the contrast is adjusted spot on, they're unreadable.
  • Country: is
  • elerepair
Re: not work
« Reply #14 on: May 28, 2014, 11:44:58 am »
hmm, and how i can fix this?
  • Country: is
  • elerepair
Re: not work
« Reply #15 on: May 28, 2014, 11:47:23 am »
its a 0,42volts
in 3rd
Offline Neganur
Re: not work
« Reply #16 on: May 28, 2014, 12:13:10 pm »
I would first check if that corrects your problem by replacing R8 and R9 by a 50k potentiometer:
Remove R8 and R9 from the board you already assembled and solder a pot in like in the attached picture.
Offline madires
  • A qualified hobbyist ;)
Re: not work
« Reply #17 on: May 28, 2014, 12:27:08 pm »
Please replace the 7805 with a 5V MCP1702 or add an external 2.5V voltage reference (download Karl-Heinz' documentation at http://www.mikrocontroller.net/svnbrowser/transistortester/Doku/tags/english/ for the details).
  • Country: is
  • elerepair
Re: not work
« Reply #18 on: May 28, 2014, 02:23:13 pm »
its samthing moor, its dont coming leters on the screen
  • Country: is
  • elerepair
Re: not work
« Reply #19 on: May 28, 2014, 02:26:12 pm »
and alsou dont make a test :(
maby samone can give me sett of this tipe tester. schematic ans hardware. schematic please in eagle file.
tx
Offline Neganur
Re: not work
« Reply #20 on: May 28, 2014, 02:58:51 pm »
Are you sure that you connected the potentiometer between +5V and GND, with the wiper going to the VO pin?
  • Country: is
  • elerepair
Re: not work
« Reply #21 on: May 28, 2014, 03:03:15 pm »
yes
Offline Monkeh
Re: not work
« Reply #22 on: May 28, 2014, 03:08:16 pm »
yes
Then perhaps you can explain why your picture showing it not working, also clearly shows that you did not connect it correctly.
  • Country: is
  • elerepair
Re: not work
« Reply #23 on: May 28, 2014, 03:16:41 pm »
yes
no, its connected corect. its samthing ealse. hu can give me new plate scheme and soft. i can build new
Offline Monkeh
Re: not work
« Reply #24 on: May 28, 2014, 03:17:27 pm »
I guess you're not interested in learning anything, then.
