Author Topic: Odd Order Active Filter Calculator  (Read 1867 times)
Offline T3sl4co1lTopic starter
    • Seven Transistor Labs
« on: March 02, 2016, 11:46:57 am »
Most calculators only show 1st and 2nd order stages.  This is a waste: in a synthesized filter (Bessel/Butterworth/etc.), odd order filters always have one real pole, which means you can simply throw in an RC pole somewhere.  So if you find that you need, say, a 4th or 6th order filter, you can sweeten it to a 5th or 7th with no problem whatsoever. :)  Of course, the RC values for the 3rd order stage aren't simply R and C, so you need a calculator to figure that out.
http://beis.de/Elektronik/Filter/Act3PoleLP.html
Seven Transistor Labs, LLC
Online moffy
Re: Odd Order Active Filter Calculator
« Reply #1 on: March 02, 2016, 10:49:07 pm »
Nice! Thanks for the info, it is always handy to have a means of calculating the filter component values.
Also the first input RC reduces the BW that the opamp sees, nice if you have a high BW input signal.
« Last Edit: March 02, 2016, 11:27:53 pm by moffy »
