Author Topic: On by default switch  (Read 1722 times)
Offline kuonTopic starter
« on: August 29, 2019, 07:39:48 am »
I have a power supply which has an inhibit pin that must either be left floating for the power supply to be on, or pulled down for the power supply to be off.
I want the power supply to be off by default when power is applied and be turned on when a control line is pulled high.
So basically, when the control line is low, the circuit must conduct, and when the control line is high it must be open circuit and let it float.
I would usually use a transistor with a pull up resistor, but the documentation of my power supply clearly state that the inhibit pin must not be pulled up.
Do you have recommendation on how to implement this?
Online oPossum
Re: On by default switch
« Reply #1 on: August 29, 2019, 08:12:53 am »
Normally closed (Form B) optocoupler
For example... https://www.mouser.com/datasheet/2/240/CPC1106N-1548424.pdf
« Reply #2 on: August 29, 2019, 07:55:53 pm »
Thanks, didn't think of the optocoupler approach. Will do perfectly.
Offline NiHaoMike
    • Facebook Page
« Reply #3 on: August 29, 2019, 11:46:53 pm »
Transistor without a pullup resistor.
BTC: 18813fu8LQEdDwH9YLM1ABed3XwCfeSeFi
Online David Hess
  • DavidH
« Reply #4 on: August 30, 2019, 12:56:37 am »
A p-channel JFET or p-channel depletion mode MOSFET if you can find one will do that.
Offline magic
« Reply #5 on: August 30, 2019, 05:38:28 am »
To turn a p-channel JFET off its gate needs to be driven higher than voltage on the inhibit input which is unknown. For an n-channel JFET, negative voltage would be required.
A normally-on OptoMOS doesn't seem like such a bad idea in these circumstances.
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #6 on: August 30, 2019, 07:12:54 am »
Perhaps you can also use a resistor. The current source on the pin is probably finite, so you could pull it down.
Then you only have to put enough voltage on the chip to turn it on again. With a slight loss in the resistor.
