Author Topic: OpAmp Diagram  (Read 8495 times)
Online Randy222Topic starter
OpAmp Diagram
« on: January 26, 2024, 06:57:20 pm »
Was browsing some opamp pdf's on a popular chip site, came across this diagram.
If the OA rails should be +2.5 and -2.5, why does the neg rail show + side of voltage attached?
Should it not be like the batt's I added?
Offline ataradov
    • Personal site
Re: OpAmp Diagram
« Reply #1 on: January 26, 2024, 07:08:10 pm »
This diagram makes no sense. if they meant that batteries would be the source of the +/- 2.5 V, then the bottom battery is reversed.
If they meant that batteries are placed in addition to some other voltages, then it makes even less sense.
Given the overall vibe of the "schematic", I would say it is just a mistake in polarity.
Alex
Offline RFDx
Re: OpAmp Diagram
« Reply #2 on: January 26, 2024, 08:00:16 pm »
The neg. rail has the plus side attached but the voltage is "-2.5V". For CAE software that is perfectly acceptable.
Re: OpAmp Diagram
« Reply #3 on: January 26, 2024, 08:04:57 pm »
We must have hit POST at exact same time, my reply did not post.
The reference appears to be GND, whatever GND is. So a "+" sign would indicate above GND, and a "-" sign would indicate below GND. That's the std, no?
« Last Edit: January 26, 2024, 08:13:58 pm by Randy222 »
Offline Bud
Re: OpAmp Diagram
« Reply #4 on: January 26, 2024, 08:18:11 pm »
Other errors aside, one battery is 1.5V , not 2.5V.
Re: OpAmp Diagram
« Reply #5 on: January 26, 2024, 08:23:04 pm »
I was just illustrating + - rails using two batts.
For argument sake, the "AA" batts in pic are each 2.5v.   ;)
Offline RFDx
Re: OpAmp Diagram
« Reply #6 on: January 26, 2024, 08:27:31 pm »
Yes, the "-" sign in front of 2.5V says that supply rail is 2.5V below ground.
The batteries represent  another (lower voltage) option to power the opamp.
Offline eutectique
Re: OpAmp Diagram
« Reply #7 on: January 26, 2024, 09:17:05 pm »
Aren't they AAA batteries?
Re: OpAmp Diagram
« Reply #8 on: January 26, 2024, 09:50:27 pm »
Did I miss an "A"?  :-DD
Maybe they are AAA, each 2.5v.
Online Zero999
  • 0999
Re: OpAmp Diagram
« Reply #9 on: January 26, 2024, 10:15:50 pm »
AA or AAA batteries are normally 1.4V (fully charged NiMH) or 1.6V (fresh alkaline), not 2.5V.
Other than that, the notation used on the schematic is correct. It's perfectly acceptable to label voltage sources negative, to denote the negative polarity, rather than connecting the positive to 0V.
The two configurations shown below are equivalent.
Offline MarkT
Re: OpAmp Diagram
« Reply #10 on: January 27, 2024, 09:55:10 am »
Oh no they're not.
Online Gyro
Re: OpAmp Diagram
« Reply #11 on: January 27, 2024, 10:29:19 am »
  X  3/10  Must try harder.  ;)
Best Regards, Chris
Offline RFDx
Re: OpAmp Diagram
« Reply #12 on: January 27, 2024, 11:29:08 am »
Offline wasedadoc
Re: OpAmp Diagram
« Reply #13 on: January 27, 2024, 12:04:02 pm »
Offline magic
Re: OpAmp Diagram
« Reply #14 on: January 27, 2024, 12:06:24 pm »
Oh no they're not.
Yes they are.
They are not.
They are equivalent if you accept the idea of negative voltage batteries whose positive terminal is negative with respect to their negative terminal.
I would prefer the abstract voltage source symbol instead of batteries here.
The following users thanked this post: Gyro
Online Zero999
  • 0999
Re: OpAmp Diagram
« Reply #15 on: January 28, 2024, 09:55:21 am »
Negative voltage batteries do exist. For example lead acid cells often charge up in the reverse polarity.
If you're going to be picky, a battery symbol isn't the right one for an 1.5V alkaline cell, since it's one cell.
Online Gyro
Re: OpAmp Diagram
« Reply #16 on: January 28, 2024, 02:02:33 pm »
I think that would count as a misused battery, and rather feeble edge case in this context.
Basically, the bottom right quadrant of your diagram is incorrect. Setting aside the multi-cell rather than single cell symbol, you can't just use a standard polarity battery symbol (complete with added '+' sign for clarity), stuff a -1.5V label next to it and have it be ok!
You either need to stick the battery symbol the other way up, or have the ground symbol connected to the top and the V- symbol to the bottom. Let's get this basic stuff right, it's not picky.
Best Regards, Chris
Online Zero999
  • 0999
Re: OpAmp Diagram
« Reply #17 on: January 28, 2024, 05:20:02 pm »
Well I just did that and everything was ok. I tried it in a simulator and it worked. I also performed calculations using Ohm's law and it adds up perfectly.
Online Gyro
Re: OpAmp Diagram
« Reply #18 on: January 28, 2024, 05:50:40 pm »
You might be able to get it to simulate ok by specifying a negative voltage, but it doesn't read ok. Schematics need to be clearly readable.
It really hadn't occurred to me that you might be relying just on simulation to show the equivalence of the two forms of representation, rather than visual correctness. I'm slightly gobsmacked. :o
« Last Edit: January 28, 2024, 06:36:15 pm by Gyro »
Best Regards, Chris
Offline magic
Re: OpAmp Diagram
« Reply #19 on: January 28, 2024, 07:05:41 pm »
In LTspice (where this picture seems to come from) these symbols are meaningless, it's always just an arbitrary voltage source.
Online Zero999
  • 0999
Re: OpAmp Diagram
« Reply #20 on: January 28, 2024, 07:53:09 pm »
Both comments are true. I chose a battery symbol, purely because that's what the original poster showed on their schematic. I wouldn't normally draw it like that, but I've seen far worse things on schematics. There are things which annoy me far more.
Online Gyro
Re: OpAmp Diagram
« Reply #21 on: January 28, 2024, 08:31:14 pm »
You might still want to post a visually accurate one for anyone without the benefit of the asc file.
Best Regards, Chris
Re: OpAmp Diagram
« Reply #22 on: January 29, 2024, 02:14:53 pm »
I think there's some confusion.
1st, I added the batts for illustrative purposes only. What those batts are, their voltage, is not relevant here.
2nd, the ckt in 1st post is from a TI PDF, I did not create the ckt illustration.
3rd, if the TI illustration indicates "-2.5v" for the OA "V-" connection, then the batt symbol used, along with the "+" sign should indicate neg voltage on OA V- pin.
Like this.
Online Zero999
  • 0999
Re: OpAmp Diagram
« Reply #23 on: January 29, 2024, 02:34:26 pm »
Like this.
No, that won't work, because voltages are relative. The op-amp'a power supply pins will  both see 2.5V. If all the inputs are nearer 0V, bad things are likely to happen.
To correct it, get rid of the negative sign.
Re: OpAmp Diagram
« Reply #24 on: January 29, 2024, 03:15:31 pm »
Like this.
Are you commenting on post #1, or the new diagram?
In the new
The V- pin shows "-2.5v"
The V+ pin shows "+2.5v"
That should be 5v rail-to-rail, +2.5 to -2.5
