Ooh thanks, I was literally looking at the AD542 - OPA140 input buffer swap that was just mentioned by David, great to see a die shot.
There are a bunch of acceptable replacements for the AD542, which I think was the first really precision integrated JFET input operational amplifier with a CMRR of 76dB minimum. The primary limitations in a follower circuit for a high impedance input are flicker noise, common mode rejection, input bias current, and input offset drift. If present, the automatic zero loop relaxes the input offset drift requirement, but may require reasonable speed and settling time. The OPA140 is about the best part available, especially considering its relatively low cost. The OPA1641 audio version is almost as good for an even lower cost.
OPA145 would also be an interesting one to compare to - not quite as good specs as the 140, but close in many ways and half the speed/price (lower speed might be a good thing in some cases).
As far as I can tell, there are 4 related parts:
OPA140 Precision, low noise, and lowest input bias current, graded and trimmed
OPA141 Raw OPA140 without trimming or grading
OPA145 Low power OPA140, so slower and slightly higher noise, see below
OPA1641 Audio, maybe they grade this one for low noise but nothing else
Chances are the OPA145 will look very much like the OPA140, just with slightly lower current used for the output stage and the bit slower compensation.
The OPA145 also has lower supply current and thus less heat, which can help with thermal effects. On the downside expect more cross over error from the output stage.
The OPA145 also has about half the differential and common mode input capacitance, so I suspect the input JFET pair was scaled in size to keep the same current density.
