I started with a basic RC RESET circuit.
Then I pondered... but it's an open drain with a pull up... and the inputs are not schmitts triggered.
For similar reasons I have a 74LVC07 hex open drain buffer on the board. Its there to allow 3v3 side to safely interact with the 5V pulled up open drains.
Plugging my RC circuit into 2 channels of that buffer to pull RESET and HALT for me "with an edge", sounded great. But now I'm not so sure as those buffers are not schmitt trigger either.
I'm going to breadboard the LVC07 to see how well it behaves with slow rising inputs.... and scar the datasheet for max rise times
In my Z80 build I just fed RESET direct from the RC circuit. It never bothered it. The 68k is a bit different though, with the open drain protocol. Granted the RC circuit I believe was a 10k into a 10uF, so a node pulling that low will only be pulling against a 10k which is my standard pull up anyway.
Am I overthinking?
DRAFT! C22 should be at least 10u, possibly 22u or 47. The "random" HALT an RESET (no prefix) are 3v3 side interfaces to those signals. I will check but Im 90% sure the buffer is tolerant of up to 5.5V on its inputs regardless of Vcc.
EDIT: The "10k standard pullup" is my CMOS default. I may opt for 4k7 for the NMOS pull ups, they are only a few cm long trace wise, but the other option I have on this board is a "variable" input voltage on the bus transcivers. I can lower their Vcc to match the CPU levels if I MUST.
