Author Topic: Open RC Datalogger  (Read 749 times)
Offline j427Topic starter
    • MetaShunt
Open RC Datalogger
« on: March 17, 2026, 10:21:43 pm »
Hi all,
I wanted to share a project I've been developing - an open-source RC car datalogger and telemetry system. It currently consists of two components: Open RC Spotter and Open RC Crew Chief. Open RC Spotter is a custom PCB (https://oshwlab.com/jakewachlin/open-rc-logger) that is mounted on your RC car, is powered by your BEC, and measures, logs, and transmits critical data such as acceleration, rotation rates, GPS speed and position, temperature of your motor and ESC, battery voltage, and throttle and steering commands. An ESP32 is the primary microcontroller and a soon-to-be-open-source firmware stack for it runs onboard. Pretty much any ESP32 dev board can be configured to be a receiver radio with ESP NOW to connect to Open RC Crew Chief (https://jwachlin.github.io/open-rc-crew-chief/). Crew Chief displays real-time data from your RC car, and can also be used to plot and analyze the logged data from Spotter.
Attached images show the Spotter PCB, Spotter mounted on my Tamiya RC car, and Crew Chief!
If you're an RC enthusiast, I want to hear from you! What would you want in a datalogger/telemetry system?
