For Scotty's design, has anyone built it with a pure DDS for the agile LO?
I've worked with the AD9912 with a 1 GHz clock and output up to 400MHz. But there are faster chips e.g. AD9914
http://www.analog.com/en/products/rf-microwave/direct-digital-synthesis-modulators/ad9914.html#product-overview
with a 3.5 GHz clock it could generate up to maybe 1.6 GHz.
Anyway it would be interesting to hear what modules/components in the Scotty design are under development and which ones are limiting performance currently.
The design is finished, you can build it and it will work
as specified.I'm not sure I understand your question. The 1st LO is agile (i.e. 1-2GHz) DDS based. The 2nd LO is fixed.
The 3rd LO again is a DDS based agile 1-2GHz LO used for the tracking generator (or as signal generator etc.)
By changing the filter path, changing high/low side mixing you can achieve the frequency ranges 0...1 GHz , 1...2 GHz, 2...3 GHz.
What performance is it that you want to extend? From what I understand, it was originally a 0...1GHz swept SA.
Trying to increase the bandwidth with the AD9912 is I think not going to work. Instead, you probably want a higher frequency LO and the used AD9851 DDS modules will still be sufficient.
If it's phase noise you want to improve, most of it comes from the PLL in the first LO I think.
http://www.scottyspectrumanalyzer.com/msaslim.html
There's a yahoo group connected to this with gerbers etc. well worth the learning experience.
But perhaps something like a CTRU from R&S is affordable too.
There is this project as well. but the project is still incomplete , good for learning.
This is essentially scotty's design, the person in the video does a great job at documenting his learning experience and own additions. (there are more episodes in his channel)
Just don't forget that a used HP SA or something like a CTRU can be had for around 400€ if lucky. So it's really also a question of if you want to afford all the effort invested to get a DIY up and running. Signal hound isn't exactly cheap either.
