I do wonder what has poor Bluetooth performance to do with the load capacitance of the main clock crystal?
If you get the capacitors really wrong, the crystal will either not oscillate at all and you won't have clock (and the MCU will either not run at all or run using an internal RC oscillator) or you would make the crystal oscillate at the fundamental instead of overtone frequency (40MHz is certainly an overtone crystal) - but then the clock would be totally off and your Bluetooth wouldn't have poor performance but would not work at all.
That's most likely what happened with those 9pF capacitors - it either was not running at all or the crystal was oscillating at the fundamental frequency which is much lower than 40MHz, so the radio tuning was totally off.
The best you could hope to achieve by tweaking the capacitor values is that you could "pull" the crystal frequency by maybe a 1MHz or so but that's all. That's totally irrelevant given that the Bluetooth frequency is derived from the internal PLL running at much higher frequency that is only synchronized with the crystal for stability. The capacitor values are never this critical to require such "tweaking" - how do you think would the manufacturer deal with component and manufacturing tolerances if this was necessary?
I wonder whether these "guidelines" are not referring rather to the
antenna matching capacitors given that you wrote:
According to the guidelines, i need to use a radio communication analyzer or a spectrum analyzer and tweak the load capacitors.
and that you obviously don't know which measurements this refers to given your questions about the measuring equipment.
Fixing poor antenna matching/design would make a lot more sense in the context of a poor radio performance.
