well, i've never met a lt3083 but that sounds truly weird, and a different problem from the Vset/Vout problem that this thread started with on the 3080. i guess you've done the obvious checking your made it right etc. you'd need pretty skinny or resistive wires to account for that voltage drop. assuming you followed dave's original circuit (or variant) i'd be wondering:
1. have you got sufficient load on the 3083 when its at rest? the lm334 bit. tho that wouldn't really account for a steady drop of Vout by current.
Yes, LM334 in place and functioning as expected... also, these issues only happen under load - same with either a power resistor or the EEV dummy load
2. does your power supply offer sufficient input voltage at higher current? is that rolling off? if you had a scope you could check its not loosing half the wave due to faulty or small input smoothing caps. (are they big enough?)
I believe so... I've been using a power adapter (12V 2A) for the time being, not going to set up the transformer / rectifier until I have the rest of the circuit worked out. I have tried other adapters and even an ATX PSU, all with same results.
3. is the voltage at V-set (from the op amp) stable or does that too drop with current. that would be odd and suggest a supply problem.
The more I've investigated, the more odd things I've found.... can't recall if v-set has been stable, but am documenting everything and will post full report when done.
4.again with a scope are you sure you haven't got any oscillation with the current limit - disconnect that pull down transistor til you get this sorted.
I've found some sporadic oscillations, but I can never duplicate the conditions. I'm going to start breaking the circuit down and do tests section by section as I build it back up.
5. if V-in is stable and the V-set/V-out increases (it shouldn't) with current then perhaps you've discovered an entirely new form of LT weirdness... who knows whats possible with these things? (LT certainly isn't going to tell us)
No, adjusting the current limit doesn't impact anything but the current limit, so at least that is working!
Thanks for the input, I'm starting to think I'll have to figure something out with the 317, but I want to try and nail down what's going on with the 3083 first.
