Author Topic: Oscillating comparator: simpler schmitt calculations?  (Read 2254 times)
Offline bitbangerTopic starter
« on: February 18, 2018, 09:49:42 pm »
Hi folks-
I'm working on a comparator circuit that switches in and out a FET based on supply/battery level. I didn't originally add any hysteresis because (basically) I thought that circuit loading (due to what the FET was switching) would only help my cause and I could get by without.
Of course immediately I saw oscillations beginning at, and until I get well away from, my reference threshold. I added some quick and dirty hysteresis and while this got me out of the woods I didn't end up with the right hsyteresis levels.
Sat down and hand calculated the circuit and my calculations match what I'm seeing. Problem is they seem pretty arduous, especially now to back calculate for targeted thresholds. Not to mention I'll need to add hysteresis to the second comparator, serving to further complicate things. Just curious if there's a better design approach to this? I'm sure I could brute force the calculations and throw them into an excel sheet to guess/check/revise, but mix in standard resistor values and it quickly seems light a nightmare. Any general suggestions on approach here?
FYI without hysteresis:
Capturing the oscillation when increasing Vin to >7.8V:
(oscillations remain until Vin>~8.18V)
CH2 (GRN) = "Trak" (1/10th of Vin)
CH3 (BLU) = "Thr2" (fixed 0.78V)
MATH (PNK) = CH3-CH2
CH4 (RED) = "SW2" (comparator output)
Closer exam: not necc. the same capture (I later reduced the comp pullup to 4.7k to decrease output risetime)
Anyway onto the addition of some feedback(R1/R2): problem was I initially failed to account for R14/R15 in my R1/R2 calcs
Lastly the calcs to confirm what I was seeing: the upper threhold was raised nearly half a volt, far too high.
(excuse the poor cell phone shot)
« Last Edit: February 18, 2018, 10:37:18 pm by bitbanger »
Offline Wimberleytech
Re: Oscillating comparator: simpler schmitt calculations?
« Reply #1 on: February 18, 2018, 10:32:41 pm »
Why not simplify things by making two R14/R15 dividers--one for each comparator.  Then use two hysteresis resistors--one from each comparator output to its respective divider.  You don't need the extra R1 resistor in either comparator circuit.
« Last Edit: February 18, 2018, 10:44:34 pm by Wimberleytech »
The following users thanked this post: bitbanger
Online Benta
« Reply #2 on: February 18, 2018, 10:48:07 pm »
Yep, that's the way to get it to work.
As you've drawn it, your positive feedback influences both comparators with unpredictable outcome.
« Reply #3 on: February 18, 2018, 10:57:51 pm »
Totally makes sense, thanks. (To be clear I hadn't made any changes to the SW1 comparator yet, just trying to sort out SW2 first)
« Reply #4 on: February 18, 2018, 11:25:24 pm »
I put this sim together...just for kicks.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #5 on: February 18, 2018, 11:54:21 pm »
Seven Transistor Labs, LLC
Offline danadak
« Reply #6 on: February 19, 2018, 12:02:06 am »
Java calculator for calculating hysteresis.
http://www.daycounter.com/Calculators/Comparator-Hystereses-Calculator.phtml
Regards, Dana.
« Reply #7 on: February 19, 2018, 12:43:29 am »
This may be relevant / helpful:
http://www.seventransistorlabs.com/Calc/ResDiv.html#three
Cool.  I clicked through your website.  I guessed that "7 transistor" harkened back to the old transistor radio days...but alas...I see you are way too young for that!  Ever heard of Madman Muntz?
Nice work...keep it up!
« Reply #8 on: February 19, 2018, 02:21:23 am »
You know I've been shown this site before but didn't even consider how useful it could be for this situation - thanks!
Offline T3sl4co1l
« Reply #9 on: February 19, 2018, 02:29:17 am »
Heh, I have... keep cutting out parts until it just stops working!
Cheers -- if you have any ideas for simple calculators you can't find anywhere else, let me know. :)
The following users thanked this post: Wimberleytech
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #10 on: February 19, 2018, 05:27:30 am »
what you want to achieve? more oscillation? (i assume ADJ is connected in someway to Vin)
reducing pullup will only make output (Vin?) falltime faster. if you want to decrease output (Vin?) risetime, increase R18 value.
