Dear XFDDesign,
don't you think that your behavior is worse than a five yr old childs? What did gave you the right to call me such way, if you, yourself, can not follow simple and clear instructions for a simple filter?
When your first response is "Bullshit," and then flap on in masturbatory grandeur, no. If you're going to approach as a grand wizard, and come up a fraud, you'll be treated as a fraud.
Where did you get that feeling, the filter should be connected one side to a high impedance current source?
So it is rally completely correct to playce the filter directly on the output!
I guess, from you. Both drains and collectors are high impedance nodes (in linear operation). Gluing a filter to them and then terminating it is still bolting a reactive network to high impedance nodes. Doubly-terminating still doesn't even solve all problems which I'll get to below.
I've said many times, the DDS has to be terminated, 200ohms to ground with a resistor (to make a norton source equivalent).
As you bag on the OP for not reading, its' fascinating that you've failed to look at the schematics in my post. There you will find that, indeed, the output is terminated, be it 50, 200, or 400. In fact, it's terminated to ground. Your post mentioned nothing about norton... but given:
Also I have clearly stated, the resulting filter have to be terminated both ends. Which part didn't you understand?
Let us quote your post in response:
Bullshit. The outputs of the DDS are whatever but current sources and should be terminated with resistors. As it is clearly stated in the datasheet. Current source is impedance in its natural form, so is the impedance defined by the terminating resistance. So it is rally completely correct to playce the filter directly on the output! If the current source is terminated with 200ohm resistor, then the output resistance is well defined 200ohm. YOu can use that directly to feed the LC network.
The phrase "terminated on both ends," is found precisely zero times. The DS mentions only singly terminating with 200 ohm resistors, which is due to the consideration of the high impedance nodes needing to be constrained to within compliance voltage. Thus far, you've yet to actually refute anything, justifying your claim of "bullshit."
Get rid of the differential output from the DDS. It can work single ended. Terminate both outputs with 200ohm resistor (as you have already) and use only the IOUT output.
Single-ended, OP could just ground the unused output and save the space of 1 resistor. Singly-terminated still won't solve the very same problem you've failed to rebut in the post I followed up with wherein math was used (as well as spice) to illustrate the problem with your self aggrandized claim.
Place another 200ohm termination resistor after the filter (so it will be terminated 200ohm both ends).
Which is a statement strangely missing in the primary "Bullshit" post you made, and even then, as I pointed out just prior to your post which I'm addressing, still isn't guaranteed, and
it is backed with mathThis is a correct way to do it. Full stop.
No, it's a remarkably piss poor attempt at saving face after you were just shown to be full of it. You've not actually refuted the points which called your "Bullshit" claim out as little more than a haphazard spaghetti-against-the-wall design methodology.
The
correct way to "do it," with regards to engineering, is to show me the math, or leave. If my math is wrong, and you're right, prove it. I have applied the math on both approaches, and shown that both still have issues which result in the appearances on the drains to be sensitive. I've backed up my claims, you haven't.
