Not really electronic related, but I have a question about out gassing. Do vacuum ovens make out gassing worse? i was under the assumption that people use vacuum ovens to limit the amount of out gassing. is this wrong? Also, when I put a material in google and put out gassing next to it, it gives me mixed results. For example, searching for silicon, the first link says it out gasses alot, but other links say Nasa used it because it does not out gas as much. Which is it?
