Author Topic: Parallel charging lithium batteries  (Read 670 times)
Offline WaldPinklerTopic starter
« on: August 03, 2022, 08:07:08 am »
I want to increase charge rate of my 12V 270Ah lithium bank.
My inverter unit has a 60A charger. I now have a 1600W generator and want to increase the charge rate when using that.
The charger is a mastervolt mass combi and has a jumper where 2 units can be parallel connected with a master and slave. There is no schematic or much technical info regarding the connection. These units are huge and very expensive ($2k+) so I want to avoid that.
I don't understand the master/slave parallel connection electronically. I believe the manual said a 2nd unit's power should be matched with the other. (they sell higher power models).
What options are there to increase the charging rate?
Can I just connect another battery charger? It seems to work fine with multiple mppt charges working at the same time.
