DIY pcbs are not that messy to do.
bare laminate - cheap, get it from auction site
200ml of positive20 photosensitive lacquer - in poland ~80PLN so roughly 20€. It's good for about 1 sq. meter of pcb
source of UV - cheapest way i found is to buy manicurist nail polish curing UV lamp. 36W type can be had for 15€ or so on ebay. + you get a crude timer
NaOH - bought in any home utility store or supermarket as drain cleaner powder (almost pure NaOH)
Some ethchant: sodium persulfate (Na2S04), HCl+H202 mix, ferric chloride - whatever you like and have access too. I prefer HCL+H202 because it doesn't need heating and is very fast acting (+you can etch aluminum paste stencils with it)
transparent film - very cheap, from any office supply
some strong solvent - acethone (nail polish remover), paint thinners etc (cheap, from pharmacy or hardware store)
~400 grit sandpaper - cheap, hardware store
abrasive cleaning powder - supermarket/home utility store
piece of acryllic or glass - cheapest i found was to buy a crude photo frame
drill - cheap-ass dremel clone from you local hardware store (dunno what you have in greece, but in Poland typically Castorama, Leroy-Merlin, OBI, Jula, Praktiker) - around 10€.
You can make whole setup for around 70-100€ i think.
