Author Topic: PCB Etching Marker Issues  (Read 12246 times)
Offline BlackCowTopic starter
    • Homebrew Tech
« on: December 17, 2009, 08:37:26 am »
So I've had good luck with the toner transfer method and ferric chloride on PCBs but sometimes I need to fix things with a marker. I found a regular sharpie didn't do the trick so I bought a special Industrial Sharpie.
It was advertised as being a "specially formulated ink for industrial use" that "remains permanent under most chemical washes"
I guess Ferric Chloride isn't one of those chemical washes  ???
Could anyone recommend a marker to use that will survive a ferric chloride bath?
GeekGirl
  • Guest
Re: PCB Etching Marker Issues
« Reply #1 on: December 17, 2009, 09:50:47 am »
A "Dalo" Pen will work :)
http://www.jprelec.co.uk/store.asp/c=689/Etch-Resist-PCB-Marker-Pen---Decon-Dalo
I used to use these back in the 80's to do PCB's by hand with Ferric Chloride etch. I switched in the 90's to Ammonium Per-sulphate.
I need to work on getting toner transfer working lol would also be nice to get copper plating working so I can do through hole ;)
Regards,
Kat.
    • Homebrew Tech
« Reply #2 on: December 17, 2009, 06:05:39 pm »
Thank you! I trust something that's specifically advertised to be for etching PCBs.
I'm curious, is there an advantage to etching with Ammonium Persulphate?
Cheers.
Edit: They only ship to the UK. I'm having trouble locating one from a place that ships to the US. I would have thought Jameco would have it!
Are there any other products like this that I would have better luck finding?
« Last Edit: December 17, 2009, 09:26:32 pm by BlackCow »
Offline qno
« Reply #3 on: December 17, 2009, 10:07:02 pm »
One advantage is that it does not make that rusty stains.
With etching I do not see any difference.
But I do only single sided.
I use the UV method. I print with a laser printer on a transparent sheet and put it under a UV light for a couple of minutes.
Then take of the protective ink with NaOH.
Why spend money I don't have on things I don't need to impress people I don't like?
GeekGirl
  • Guest
« Reply #4 on: December 18, 2009, 09:27:20 am »
Online Simon
  • Global Moderator
    • Simon's Electronics
« Reply #5 on: December 18, 2009, 01:31:52 pm »
you can get the pens at a stationery shop, don't pay big bucks to rip off companies like maplin that see permanent marker pens for X 10 their value
Offline APS
« Reply #6 on: December 31, 2009, 02:12:24 am »
For corecting toner transfer I use permanent markers that are used for writing on CD/DVD. You can find these with the range of tip size.
I usually put the paint twice. Put the first coat let it dry and stipple next coat over it.
Online Simon
  • Global Moderator
« Reply #7 on: December 31, 2009, 07:12:56 am »
yes those are the same pens that electronics suppliers sell as PCB pens for ridicolous prices
