Author Topic: PCBGolf: $1,000 PCB layout challenge  (Read 2207 times)
Offline adeebTopic starter
    • comma
« on: September 10, 2026, 08:48:04 pm »
We took one of our real products and design a fun "code golf" style challenge around it.
https://github.com/commaai/PCBGolf/
The following users thanked this post: liteyear
Offline Alex Eisenhut
  • Place text here.
Re: PCBGolf: $1,000 PCB layout challenge
« Reply #1 on: September 12, 2026, 11:13:06 pm »
I predict difficulty with the barrel jack.
The following users thanked this post: abeyer
Online Analog Kid
« Reply #2 on: September 12, 2026, 11:39:25 pm »
Heh; does this remind anyone else of this?
"AI: if I want to wash my car, would it be better to drive or walk to the car wash?"
Offline jnk0le
« Reply #3 on: September 13, 2026, 12:02:33 am »
Offline ZGoode
« Reply #4 on: September 13, 2026, 12:31:13 am »
That is certainly a board....................I get this is AI.........but that component layout hurts me.  You'll be giving any EMI/EMC people a heart attack with this
Online aeg
« Reply #5 on: September 13, 2026, 02:03:49 am »
It's OK, they doubled up on the reference designators to make up for the layout.
Offline negativ3
  • Country: th
« Reply #6 on: September 13, 2026, 02:22:14 am »
Be able to hit a ball quite far with that on the end of a stick.
Offline robzy
« Reply #7 on: September 13, 2026, 02:54:18 am »
Ha, this looks like a lot of fun! I'll give it a shot this week.
Offline jnk0le
« Reply #8 on: September 13, 2026, 11:23:30 am »
To be honest, a winning submission is not gonna pass FCC tests.
BTW, rules are also a bit lacking:
- can the components be placed on both sides?
- can we change components? (different footprints or complete redesign)
- can we reroute pins on stm?
- can we add extra components? (0ohm resistors etc.)
- can we remove "unnecessary" components while retaining functionality?
- can it be panelized in any way? The following allow to hang connectors of the edge still allowing automated assembly.
- if a connector hangs of the edge, does it extend bounding box?
- can it be manufacturable only with the most expensive options? (0.1mm via etc.)
- can we apply a chinese definition of "working and usable"?
EDIT:
- can we use/add THT components? (1x 10M resistor gives you 2 uncounted vias)
« Last Edit: September 13, 2026, 11:45:54 pm by jnk0le »
The following users thanked this post: hans, Someone, tooki, liteyear
Offline thm_w
  • Non-expert
« Reply #9 on: September 15, 2026, 01:21:02 am »
Yeah I don't think its fair to allow adding/removing of components, its going to make it insanely complicated if you do.
5000 points for a second layer is equivalent to ~50x50mm of extra board area. So I think 1 layer board is the ticket.
No vias if possible (50 points) as a single 0402 jumper would be only ~0.2 points, if they were allowed. If not single layer might not be possible.
Offline hans
« Reply #10 on: September 15, 2026, 07:52:08 am »
Without mechanical constraints on connectors, this exercise is a bit pointless imo. Otherwise, indeed, I would put the barreljack on middle of the PCB, argue a bunch of 0402s get assembled first and nobody asked the barreljack needs to be mounted flush on the PCB. There are so many rules to bend.. the PCB artwork is often not the problem.
Offline abeyer
« Reply #11 on: September 15, 2026, 08:27:55 pm »
I suspect they're not too worried about either of those... if you click through you'll see they use this as a recruiting puzzle, so they're probably more looking for what people can come up with than for a working product or well specified contest rules.
    • comma
« Reply #12 on: September 22, 2026, 06:39:42 pm »
Exactly, it’s just a fun puzzle. This board isn’t getting made or used. We updated the rules to answer some questions; use your best judgement.
Offline thm_w
  • Non-expert
« Reply #13 on: September 22, 2026, 10:18:09 pm »
You didn't answer the questions above about adding jumper resistors or removing capacitors. Though it sounds like the second one is allowed if the board works.
Rules
    The bare PCB must be fully manufacturable by JLCPCB.
    It must be possible to actually assemble the PCBA.
    The assembled product must work and be usable.
    Mating connectors must remain mechanically and electrically compatible.
    Optimizations that require firmware changes are allowed.
Offline DebboR
« Reply #14 on: September 23, 2026, 09:24:21 am »
Jumper resistors are fine. BOM/schematic changes are totally in scope, definitely encouraging creative solutions!
(i also work at comma)
